查看: 2445|回复: 2
转帖[分享]几个著名的老外飞手的配件,机架,参数
发表于 2015-7-25 16:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://bbs.5imx.com/bbs/forum.php?mod=viewthread&tid=1106872&extra=page%3D3
不断更新19/7/2015
已下是在youtube里著名的200-300mm穿越的飞手。
翻墙出去youtube 订阅他们的视频吧。
Charpu      美国  Luminier赞助-
Juz70        美国
机架Lumenier QAV250 carbon fibre edition http://www.getfpv.com/multi-rotor-fra...
电机座QAV250 10° Motor Tilt kit  http://store.ivc.no/product/qav250-ti...
飞控Naze32 flight controller http://www.getfpv.com/flight-controll...
电调DYS SN20A ESCs
电机Cobra 2204 2300kv motors http://www.getfpv.com/cobra-cm-2208-2...
浆HQ 5x4.5 bullnose props http://www.getfpv.com/hqprop-5x4-5-bu...
摄像头Lumenier CS-600 super camera http://www.getfpv.com/lumen...
图传ImmersionRC 5.8ghz 600mW Vtx  http://www.getfpv.com/5-8ghz-600mw-vi...
天线Circular Wireless SPW58 5.8GHz Antenna http://www.getfpv.com/circular-wirele...
电池Lumenier 1300mAh 4s 60c Lipo Battery  http://www.getfpv.com/batteries/fligh...
狗Gopro Hero 3+ black 1080p 60fps http://www.getfpv.com/gopro...
接收器Frsky D4R-II receiver http://www.getfpv.com/radios/receiver...
FrSky Taranis 2.4ghz transmitter http://www.getfpv.com/radios/radio-co...
Fatshark Attitude SD 2 goggles http://www.getfpv.com/fatshark-attitu...
ImmersionRC 5.8 ghz duo receiver http://www.getfpv.com/immersionrc-duo...
ImmersionRC CP patch antenna http://www.getfpv.com/5-8-ghz-spirone...
Naze32 settings
CleanFlight
Firmware Version 1.9.0
PID controller 1
oneshot125 enabled
Looptime 1200
Roll P 5.4 I 0.030 D 35
Pitch P 3.8 I 0.020 D 25
Yaw P 11.0 I 0.050 D 1
Roll rate 0.99
Pitch rate 0.99
Yaw rate 0.78
TPA 0.40
TPA breakpoint 1400
RC rate 0.75
RC expo 0.75
throttle expo 0.00
 楼主| 发表于 2015-7-25 16:13 | 只看该作者
Boris B.    美国   Cobra赞助
My Full Setup:
- Blackout Mini H 5Inch (220 version)
- Cleanflight (Special version with Pterm,Dterm, soft gyro filter)
- SpracingF3 http://seriouslypro.com/spracingf3 (Beta Cleanflight software)
- DYS SN20 http://www.multirotorparts.nl/electro...
- Cobra 2206/20 2100kv http://www.multirotorparts.nl/motors/...
- Hoverthings 10degree tilted motor mount
- HQProp 5x45 bullnose http://www.multirotorparts.nl/propell...
- Sony PZ0420 Sony SuperHAD 600 FPV camera
- 4S 1900mAh MRP test lipo
- Fatshark Dominator V2 + Immersion 8dbi patch
- Immersion 5.8 600mW vtx http://www.immersionrc.com/
- Frsky Taranis w telemetry D4R-II http://www.multirotorparts.nl/electro...
- Gopro Hero4 Black
Settings:
Blheli Settings:
blheli 14 https://dl.dropboxusercontent.com/u/3...
Naze32 settings:
looptime 800 (1,25khz rock stable almost no jitter)
oneshot125
gyro_lpf = 256
set dterm_cut_hz = 12
set pterm_cut_hz = 50
set gyro_cut_hz = 100
set pid_controller = 1
set p_pitch = 58
set i_pitch = 32
set d_pitch = 35
set p_roll = 33
set i_roll = 28
set d_roll = 26
set p_yaw = 98
set i_yaw = 65
set d_yaw = 15
tpa_breakpoint = 1500
tpa_rate = 50
set rc_rate = 100
set rc_expo = 70
set rc_yaw_expo = 35
set pitch_rate = 60
set yaw_rate = 100
set min_command = 1000
set min_check = 1020
set min_throttle = 1080
set pid_at_min_throttle=1
发表于 2015-7-28 17:27 | 只看该作者
