楼主: lizhou0631
SR-71怪物的制作过程-云下的月光
 楼主| 发表于 2016-6-23 19:55 | 只看该作者
继续
发表于 2016-6-24 13:19 | 只看该作者
呵呵持续关注
83
发表于 2016-6-24 13:21 | 只看该作者
原作者很啰嗦,楼主可以简化下。真正有需要的楼主可以打包分原档
84
 楼主| 发表于 2016-6-24 15:59 | 只看该作者
先这样了,对于初学者,碎碎的便于理解
85
发表于 2016-7-1 08:43 | 只看该作者
这么多天没有更新了,楼主努力吧,谢谢!
86
发表于 2016-7-1 09:53 ——“来自手机” | 只看该作者
这太棒了,顶楼主,谢谢楼主
87
发表于 2016-7-1 12:46 | 只看该作者
太棒了!期待下文。。。。。。
88
 楼主| 发表于 2016-7-3 15:38 | 只看该作者
继续
89
发表于 2016-7-13 09:10 | 只看该作者
这个帖子好像要烂尾了,楼主努力啊
90
发表于 2016-7-15 14:28 | 只看该作者
楼主,原地址给我,我也能翻译
91
发表于 2016-7-15 14:39 | 只看该作者
楼主你的翻译果然够渣渣,6.8尺的翼展叫你翻成2.7寸,还好45磅和13尺两个数据叫我锁定了原贴。制作人名叫Lance Campbell,他的原帖地址http://www.mmrca.org/lance/sledframe.html。看不懂英语的可以看看热闹,想看翻译的可以等一等。
92
发表于 2016-7-15 14:44 | 只看该作者
Once all the blocks were down, another 4 layers of 4 ounce cloth go over the top.  In-between the blocks, is open air, between the 2 major glass layers:
等所有的木块固定,将另外四层4盎司布料覆盖其上。木块空隙中,是两层玻璃面板之间的空气:
93
发表于 2016-7-15 16:19 | 只看该作者
And now the problem.....or I should say the 3 problems. The major one is that when I started spraying Duratec primer over the PVA, it did not look right. It looked too 'wet' too quick. I had waited an hour, when the instructions said only 20-30 minutes was needed, but the bottom line was that even after an hour, it was still not dry. The primer mixed chemically with the PVA, causing the fogging you see, and making an edge to the mold next to the part look like crap. Secondly, taking the blocks all the way to the edge, means that they are not sealed, and that they could easily absorb water when washing the mold off. Lastly, when drilling through what would be 2 mold halves to install the bolts and wing nuts to clamp them together, making sure there are balsa blocks on both sides at the exact spot would not be easy either. Thankfully, the original came out of the first failed attempt just fine. Off to try again....
现在问题来了……或者我应该说是三个问题。最主要的是当我用Duratec primer在PVA上喷涂时,看起来不太对头。它看起来太湿,流的太快。使用说明说只需要20-30分钟固化,我却等了一个小时,而且最后可能还不止一个小时,漆还没有干。喷漆和PVA发生了化学反应,生成了你们看到的雾状表面,并且让磨具靠金工件的一条边看起来像坨屎。第二,木块非常靠边,意味着他们并没有被密封起来,这就让他们能在清洗模具时能轻易地吸收水分。最后,当钻通对半模具的螺栓和翼形螺母夹紧孔时,要确定该点两侧都有巴莎木也是不太容易。辛亏,第一次尝试失败,但原件还可以使用。偏一点再试一遍……
94
发表于 2016-7-15 18:40 | 只看该作者
留爪
95
发表于 2016-7-18 13:07 | 只看该作者
点进来看不到我还以为被删帖了。。。。
1/1/2004
[size=+1][size=+1]Back on Track...
回归正轨
You can only do so much reading, research so many products, and talk to others about this process.  Eventually you have to do it yourself, and find out in a couple of days, if all of the chemicals and products   you've assembled will play nice with each other.  Last update you saw the ending result of a problem with the    PVA.  I've now changed my timing of my process, and found that all the chemicals I've gathered do work well,         if I let them have the proper time to cure and dry.
Success can be seen below and I now have my first set of usable molds!  2 years so far, and finally I've got my first molds.
I improved my balsa block idea a bit, and did not put them out on the flange.  That makes putting the bolts and wing nuts in, used to clamp the two mold halves together, easy. I can also put them where ever I want.   Secondly, it seals the edges easily, so that the molds can be washed, to remove the PVA after use.
第一段是说他很辛苦,很努力,发现只要让各种化学品有时间干燥稳定,就不会发生互相反应的现象。
第二段是说将要有自己的模具了他很高兴。
第三段是说模具夹持方法改进为四周,好布局,好取模。
96
发表于 2016-7-18 13:13 | 只看该作者
It turns out that I, out of paranoia of hurting my original plug, put on my PVA a bit heavy, which means it takes a couple hours to fully dry out.  For now, my process will be, for example, shoot PVA before work,  say on a Friday morning.  Shoot my Duratec primer after work that Friday night.  Then be able to get up Saturday   and lay up the mold(s).  The molds you see below, of the outboard elevators, have 14 layers of resin and cloth    out on the flange, and 8 layers in the middle (4 below the blocks and 4 above), so you need a full day set         aside to get that many layers down properly.
这段是说他在制造时间上的控制,一天喷漆一天支模一天干燥一天扯布啥的。
Now that I'm getting the process down, I'll try doing more parts at once.  Next will be building the molds for both wing tips at the same time.
现在我已熟练这套流程,我会试着一次制造多个部件。下次就会同时制作双翼翼尖的模具。
97
 楼主| 发表于 2016-7-18 13:47 | 只看该作者
rapemyself 发表于 2016-7-18 13:13
It turns out that I, out of paranoia of hurting my original plug, put on my PVA a bit heavy, which m ...
朋友,看来你英文不错,我英文是渣渣,给各邮箱,我把原文给你,能不能在我基础上修改,我已经翻译了70页了
98
 楼主| 发表于 2016-7-18 13:51 | 只看该作者
最近工作换地方了,东西还没有搬,几天后持续更新
99
发表于 2016-7-18 14:57 | 只看该作者
lizhou0631 发表于 2016-7-18 13:47
朋友,看来你英文不错,我英文是渣渣,给各邮箱,我把原文给你,能不能在我基础上修改,我已经翻译了70页 ...
也得查字典,凑合用。发到imsickinthecorner@163.com
100
 楼主| 发表于 2016-7-19 09:53 | 只看该作者
rapemyself 发表于 2016-7-18 14:57
也得查字典,凑合用。发到。
ok
