楼主: rcspeed
65CM遥控帆船--Dragon Force 介绍
发表于 2015-9-12 22:56 | 只看该作者
帆都改了, 有比較好跑嗎
发表于 2015-9-14 01:02 | 只看该作者
把重心点向前移一些。会更好。
 楼主| 发表于 2015-9-15 10:52 | 只看该作者
f14tomcatedf 发表于 2015-9-14 01:02
把重心点向前移一些。会更好。
是的,船尾拖在水里,我正想着换个压铅把重心往前移一点
44
 楼主| 发表于 2015-9-15 11:13 | 只看该作者
星期天俱乐部活动
45
发表于 2015-9-15 11:50 | 只看该作者
你在澳洲柏斯?
发表于 2015-9-15 14:35 | 只看该作者
rcspeed 发表于 2015-9-2 13:36
楼上下手好快哦,你买的是最新版本,改了舵机安装方向,改了开关的位置。
建议稳向板可以切掉50mm
为啥要切割50mm  还有就是 换350克的压铅 符合 65规则么?
47
发表于 2015-9-15 15:06 | 只看该作者
DF65是自成一局的OD,它的競賽規則請自行搜索DRAGON FORCE RESTRICTED CLASS RULES,
基本上,短龍骨只能自己玩玩,正式比賽是不被允許
Section D - Keel & Rudder
D.1 In the event of damage, the keel and rudder may be sanded, faired and re-painted as close to supplied section and finish as possible.
D.2 Any moulding flashing around the edge of the rudder may be sanded flush.
D.3 In the event of damage the Keel Ballast Bulb may be repaired and re-painted.
D.4 The hole in the base of the Keel Ballast Bulb shall not be covered or filled.
D.5 The short Keel available from the Builder as an accessory is not permissable in official Dragon Force Restricted Class events. It is available to allow the boat to be enjoyed in local, shallow water conditions for casual or club sailing.
至於RG65的規則主要是限制船的長度,船桅的高度,帆的總面積對於重量似乎沒有特別明文規定擷取某站對RG65的說明
The RG-65 is an International development class with a 30 year history. The class rules limit only the length of the hull (65 cm), the height of the rig (110 cm) and the sail area (2250 square centimeters). The class originated in Argentina and is popular in South America and Europe.
Boats are light, quick, and responsive. A typical boat weighs 1 kilogram with a l lb or 500 gram trolling sinker for a bulb. Many designs can be found on the Internet and some kits are on the market and under development. A competitive balsa-hulled boat can be built for well under $200, radio included, and easily transported in even the smallest of cars.
The Class is managed in the U.S. by a Class Owners Association which is accredited as the National Class Authority by the RG-65 International Class Authority.
48
 楼主| 发表于 2015-9-16 08:27 | 只看该作者
为了改善小风时候的启动,换压铅切稳向板在DF规则都是不允许的,但我这个在RG65规则下没有问题
49
发表于 2015-9-18 08:48 | 只看该作者
VINTAGE30 发表于 2015-9-2 09:47
来还图了  我现在购买的是 201504版
说这个是RTR套装其实是不准确的 应该就是个KIT 装了2个多小时
些船已从600元左右,涨到了1060元,性价比应该是失去了
50
发表于 2015-9-18 09:41 ——“来自手机” | 只看该作者
商人啊,伤人~~  如果版主不介绍龙力,会有人去注意他家的船嘛?!  因为有了些市场坐地涨价,有点那个了~~~  原本帆船就阳春白雪,为何不多造福些模友,帆友多了口碑好了,市场占有率会少嘛~~~哎!
51
发表于 2015-9-18 09:45 | 只看该作者
票风 发表于 2015-9-18 09:41
商人啊,伤人~~  如果版主不介绍龙力,会有人去注意他家的船嘛?!  因为有了些市场坐地涨价,有点那个 ...
说的很在理,我看到性价比很高还在考虑也买一条玩玩,现在还是玩MM530吧
要求商人在利益面前,那是不可能的
52
发表于 2015-9-18 10:42 | 只看该作者
53
发表于 2015-9-18 17:25 | 只看该作者
之前590,我们一次买了8条回来。对比从美国Amazon网上买回来的船,质量上没有任何区别。
54
 楼主| 发表于 2015-9-25 07:32 | 只看该作者
是啊,这个商铺有点不仁义了,有销量应该降价的
55
发表于 2015-9-25 13:36 | 只看该作者
升价了  看了下 四位数 店家能 国外国内那碗水能端平么?比国外卖的海龟。。。。。。
56
发表于 2015-9-27 07:00 | 只看该作者
有没有澳洲销售地址,在澳洲亚马逊没找到
57
发表于 2015-9-28 20:27 | 只看该作者
cover 发表于 2015-9-6 08:52
我的880装了N久了 还没装好。等你一起下水啊
这还真是不好拿
58
要求商人在利益面前,那是不可 ...
嘿 这把我恶心到了
59
发表于 2015-9-29 16:56 | 只看该作者
VINTAGE30 发表于 2015-9-28 20:27
嘿 这把我恶心到了
再回到590元,已不可能了
60
发表于 2015-9-30 10:27 | 只看该作者
http://www.rcyachts.org.uk/epages/Store3_Shop2540.sf/en_AU/?ObjectPath=/Shops/Store3.Shop2540/Categories/Dragon_Force_65
澳币和人民币大约是1:4.5  咋滴国内就买不到
