楼主: 00782
新兵报道!送点见面礼!纸飞机高手进阶!给穷人带来快乐,为富人开拓思维!
发表于 2007-10-17 15:05 | 只看该作者
偶折过第二种···:em14:
发表于 2007-10-17 15:34 | 只看该作者
不错,不知道哪种滑行性能好一点!
发表于 2007-10-17 15:46 | 只看该作者
我只會第二种,,
原來飛機可以這麽折。。
发表于 2007-10-23 11:49 | 只看该作者
收藏着再说 谢谢了 LZ再贴几个简单好飞的纸飞机上来,我们天天顶!
 楼主| 发表于 2008-3-11 20:05 | 只看该作者
J - 40
" Another jline original"
The J-40 has been completely updated with new images to enable you to fold it more easily. Give it a try and let us know how you do in folding the all new J-40.
" J - 40"
# 1Start with a sheet of paper measuring 8 1/2 x 11 inch. or 21.5 x 28 cm in half. Red line indicates were to fold. See illustration.
# 2Fold the top two corners down. See illustration.
# 3Fold the corners back out. See illustration.
# 4Fold along red line. See illustration. Then unfold.
# 5Fold left and right wing tips in along red lines.
# 6Now fold over again. See illustration.
# 7Fold nose down at red line. Please read helpful hints.
# 8Fold plane in half, making sure nose triangle is on the inside.
# 9Make a mark at the top 3/8 ". And at the bottom 3/4 ". This is indicated in red and this is where your fold will be. See illustration. Do the same for the other wing.
#10Make a mark at the top 5/8 ". And at the bottom 1-1/4 ". This is again, indicated in red and this is where your fold will be. See illustration. Do the same for the other wing.
#11This is a view from the bottom of the plane.
#12This is a view from the rear, as if the plane was flying away from you. Your plane should look like this when in flight.
Here are some helpful hints:#13In step # 7, you fold the nose back at the red line. This is shown in the illustration on your left. This plane must be balanced correctly (c.g) I use 75 pound paper to create this plane and it works very well. However do to weight (thickness of paper) paper and A-4 paper you may need to make some adjustments. You can correct this problem by doing the following.
  • If your plane tends to nose dive, you must make your fold more towards the back of the plane. What this means is that you will be folding more of the nose over. Try playing with the amount you fold over and you will be glad you did, because this is truly a great plane.
发表于 2008-3-13 20:13 | 只看该作者
第9种把机翼卷起来性能贼好
发表于 2008-3-20 19:09 | 只看该作者
呵呵!
  不错,小时侯追求的东西啦!!
发表于 2009-2-22 19:28 | 只看该作者
顶啊
发表于 2009-2-25 00:00 | 只看该作者
:em26:
发表于 2009-11-24 10:52 | 只看该作者
:em01:
发表于 2009-11-25 15:40 | 只看该作者
这个有意思  ~~~小时候  手一闲下来
就折飞机完~~~
发表于 2009-12-19 07:33 | 只看该作者
这些涂装很漂亮,收藏一下
发表于 2009-12-19 08:03 | 只看该作者
成都小财神 威望+10 发帖鼓励
发表于 2009-12-21 13:12 | 只看该作者
路过
发表于 2010-1-4 14:27 | 只看该作者
:em26: :em15:
发表于 2010-1-15 01:19 | 只看该作者
有意思
发表于 2010-1-15 01:28 | 只看该作者
顶贴!找到小时候的感觉!
发表于 2010-1-16 11:23 | 只看该作者
好!:em26:
发表于 2010-1-20 13:32 | 只看该作者
:em26: 好玩
发表于 2010-1-23 17:37 | 只看该作者
很漂亮。等天暖和了也做几个玩。
