http://copter.ardupilot.com/wiki/tricopter/
Copter 3.3 (and higher)
MOT_YAW_SV_MIN: yaw servo’s lowest PWM value before binding occurs.
MOT_YAW_SV_MAX: yaw servo’s highest PWM value before binding occurs.
MOT_YAW_SV_TRIM: yaw servo’s PWM value close to what is required to keep the tail from spinning.
MOT_YAW_SV_REV: yaw servo’s reverse setting. +1 = servo moves in default direction, -1 to reverse direction of movement.
Copter 3.2.1 (and earlier)
RC7_MIN: yaw servo’s lowest PWM value before binding occurs.
RC7_MAX: yaw servo’s highest PWM value before binding occurs.
RC7_TRIM: yaw servo’s PWM value close to what is required to keep the tail from spinning.
RC7_REV: yaw servo’s reverse setting. +1 = servo moves in default direction, -1 to reverse direction of movement.
